Headlight question.
  • Headlight question.
    can the headlight switch be cleaned somehow, or does it need to be replaced? I have done the long leg cartridge fuses, I have turn signals, running lights, but no headlights. Help!
    Spray with WD-40 or electrical contact cleaner. My headlights and wipers used to go off intermittently until I sprayed WD-40 into the ignition keyhole. A few years later it started again so I sprayed again.
      The factory grease inside the switch gets so thick
      it holds the contacts apart. Cold makes it worse.
      A good penetrating oil applied where it can get into
      the switch is good. It's possible to disassemble
      the switch and clean it but it's also possible you
      might not contain all the springs
        you may want to check the relay under the hood, it's in the inner apron behind the left headlight under the wiring harness. fan relay with blue plug in is next to it in a rubber cover. once you locate it, carefully pull the cover off, then hold the contact and your headlights should come on. It's not common for them to fail, but i have had a couple go bad without notice.
        91 Festiva GL "Scrat"
        82 Honda Goldwing GL1100i
        85 BMW 535is "Brunhild"
          Thanks All, I will give it a try and let you know!
            Where could I get a new relay? AutoZoned looked at me like I don't speak English, and then she couldn't be bothered to tell me where I could get one because she had Customers, (what am I, Chopped Liver?) lol! Am I going to have to get it at the dealer? Should I take my own Vaseline? Ugh!
              Oh, BTW, I did try the WD-40 thing, but still no headlights. However, my ignition switch, turn signals and wiper lever run Silky Smooth! Thanks~
                Where are you located? Someone nearby may have one you can try.
                  I aasume you pulled the cover, touched the contacts and they came on?
                    When I looked, both the white and blue relays were just laying there? I cleaned the contacts, touched them together, still nothing. Shouldn't they be grounded to something? Also I have no cigarette lighter power, but do have turnsignals, and running lights.
                    Ugh! Help!
                      I have a good headlight/wiper switch assembly with clockspring attached I can sell you. It came from a 94 aspire, but it should bolt on swap with the festiva column. the socket has been cut off of it so you would need to splice the wires to your socket. Pm me if you want it.
                      2008 Kia Rio- new beater
                      1993 Festiva- Fiona, DD
                      1997 Aspire- Babyspire, DD
                      1994 Aspire - Project Kiazord
                      1994 Aspire- Crustyspire, RIP
                        Ugh! Help!
                        Sounds like the fuse in the fuse panel in the dash. The other fuse is on the left shock tower marked "HEAD"
                          I am publishing a video of me removing my headlight switch on my 92' Festy to YouTube right now. Maybe it will help you disassemble and clean yours. After I cleaned mine I have had no problems with my headlights as of yet.
                          It should be up shortly on my YouTube channel
                          http://www.youtube.com/dracallis
                          ~Zach
                            GREAT NEWS!!!!
                            Searched through some old threads and found that an Escort headlight relay is a perfect fit. Checked ebay, and got one BRAND NEW, DELIVERED for $13.99.
                            Super fast shipping too!
                            Visit the eBay store pautoparts
                            Standard/Tru-Tech RY225T Headlamp Relay
                            Item condition: New
                            Compatibility: See compatible vehicles
                            Quantity:
                            More than 10 available
                            Price: US $13.99
                            Shipping: FREE Standard Shipping
                            | See all shipping details
                            Delivery:
                            Estimated between Fri. Mar. 2 and Thu. Mar. 8 help icon for Estimated delivery date - opens a layer
                            Returns:
                            30 days money back or item exchange, buyer pays return shipping | Read return policy details
                            Learn moreabout eBay Buyer Protection - opens in a new window or tab
                            Find out more about the Top-rated seller program - opens in a new window or tab
                            Member id pautoparts ( Feedback Score Of 995Purple star icon for feedback score in between 500 to 999)
                            100% Positive feedback
                            Get fast shipping and excellent service from eBay Top-rated sellers.
                            Consistently receives highest buyers' ratings
                            Ships items quickly
                            Has earned a track record of excellent service
                            Save this seller
                            See other items from this seller
                            Visit store: Ebay Storespautoparts
                            Other item info
                            Item number: 160703448623
                            Item location: North Hollywood, California, United States
                            Ships to: United States
                            Payments:
                            PayPal, Bill Me Later See payment details
                            History: 1 sold
                            Credit or debit card through PayPal
                              opps wrong thread
                              Tedra Ortega :female:
                              '11 Ford Fiesta Sparkling Red (my daily ride)
                              '06 Chevy Silverado 1500 LT (hubby daily ride till we get the "little roadster" running - beep! beep!)
                              '91L Festiva white "LITTLE ROADSTER", "I survived Hurricane IKE" :cool:, 5-speed
