can the headlight switch be cleaned somehow, or does it need to be replaced? I have done the long leg cartridge fuses, I have turn signals, running lights, but no headlights. Help!
Headlight question.
Spray with WD-40 or electrical contact cleaner. My headlights and wipers used to go off intermittently until I sprayed WD-40 into the ignition keyhole. A few years later it started again so I sprayed again.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
The factory grease inside the switch gets so thick
it holds the contacts apart. Cold makes it worse.
A good penetrating oil applied where it can get into
the switch is good. It's possible to disassemble
the switch and clean it but it's also possible you
might not contain all the springs
you may want to check the relay under the hood, it's in the inner apron behind the left headlight under the wiring harness. fan relay with blue plug in is next to it in a rubber cover. once you locate it, carefully pull the cover off, then hold the contact and your headlights should come on. It's not common for them to fail, but i have had a couple go bad without notice.Last edited by kartracer46; 02-13-2012, 04:25 PM.91 Festiva GL "Scrat"
82 Honda Goldwing GL1100i
85 BMW 535is "Brunhild"
I have a good headlight/wiper switch assembly with clockspring attached I can sell you. It came from a 94 aspire, but it should bolt on swap with the festiva column. the socket has been cut off of it so you would need to splice the wires to your socket. Pm me if you want it.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Sounds like the fuse in the fuse panel in the dash. The other fuse is on the left shock tower marked "HEAD"Originally posted by IrishFiesta View PostWhen I looked, both the white and blue relays were just laying there? I cleaned the contacts, touched them together, still nothing. Shouldn't they be grounded to something? Also I have no cigarette lighter power, but do have turnsignals, and running lights.
Ugh! Help!91 Festiva GL "Scrat"
I am publishing a video of me removing my headlight switch on my 92' Festy to YouTube right now. Maybe it will help you disassemble and clean yours. After I cleaned mine I have had no problems with my headlights as of yet.
It should be up shortly on my YouTube channel
http://www.youtube.com/dracallisLast edited by ztittle; 02-19-2012, 11:44 AM.~Zach
GREAT NEWS!!!!
Searched through some old threads and found that an Escort headlight relay is a perfect fit. Checked ebay, and got one BRAND NEW, DELIVERED for $13.99.
Super fast shipping too!
Visit the eBay store pautoparts
Standard/Tru-Tech RY225T Headlamp Relay
Item condition: New
Compatibility: See compatible vehicles
Quantity:
More than 10 available
Price: US $13.99
Shipping: FREE Standard Shipping
| See all shipping details
Delivery:
Estimated between Fri. Mar. 2 and Thu. Mar. 8 help icon for Estimated delivery date - opens a layer
Returns:
30 days money back or item exchange, buyer pays return shipping | Read return policy details
Learn moreabout eBay Buyer Protection - opens in a new window or tab
Find out more about the Top-rated seller program - opens in a new window or tab
Member id pautoparts ( Feedback Score Of 995Purple star icon for feedback score in between 500 to 999)
100% Positive feedback
Get fast shipping and excellent service from eBay Top-rated sellers.
Consistently receives highest buyers' ratings
Ships items quickly
Has earned a track record of excellent service
Save this seller
See other items from this seller
Visit store: Ebay Storespautoparts
Other item info
Item number: 160703448623
Item location: North Hollywood, California, United States
Ships to: United States
Payments:
PayPal, Bill Me Later See payment details
History: 1 sold
Credit or debit card through PayPal
opps wrong threadLast edited by tedraortega; 03-24-2012, 06:29 PM.------------------
Tedra Ortega :female:
'11
Ford Fiesta Sparkling Red (my daily ride)
'06 Chevy Silverado 1500 LT (hubby daily ride till we get the "little roadster" running - beep! beep!)
'91L Festiva white "LITTLE ROADSTER", "I survived Hurricane IKE" :cool:, 5-speed
