I might have a spare cover I can sell you, let me check the condition first and I'll send you a picture.
alternator help please.
Remove the cover entirely for testing purposes, and as you are the
tester, keep yours and all others fingers out of there while running
the engine. Monitor the leaks while using the car as you normally do.
You should spot the leak(s) sooner or later. Front crank seal,
dip stick tube, front of oil pan, cam seal and valve cover seal
can all contribute. Check that the PCV system is capable of handling
the crankcase blow-by without building pressure behind gaskets and seals.
Clean the area thoroughly, replace all parts you wish to renew then
monitor once more to verify a dry engine. Finish however you wish!
Paint, airbrushed stick figure scenes on the cover whatever
^ +1 on the CD2, i love that stuff!!!Originally posted by kartracer46 View PostAdd some CD2 in the black bottle for a few oil changes, it may soften the seal up good enough till you can get it replaced.
DO NOT run thicker oil to stop a leak, thicker oil = higher oil pressure = more pressure on seals = faster leaks.Trees aren't kind to me...
thanks for all your help guys. well.. i took the cover off yesterday and found out the oil pan gasket, front seal, cam seal are all leaking
there is oil every where since i had to take the cover off due to the squealing. im going to have to replace everything asap and im going to take advantage and knock out the valve cover gasket too... what a day.
