After a failed attempt at wiring in a LED flasher, I heard a "pop". It actually sounded like the flasher was attempting to work. I then installed the oem flasher back in. I am sure the oem flasher is good.
I have no turn signals but the hazards function fine. I have checked the fuses under the dash. All are fine.
Is there another relay or something else to check?
