Originally posted by timmay89
rear strut - need hints
Yesterday I was forcing myself not to think what happens if I kill the thread inside this nut...rusEfi - DIY ECU
93 EFI: tach cluster, aspire mirrors & spindles. ZX2 master cylinder, BP+G25 swap with a door hinge, rio struts. 205/50r15, 140mph speedometer,rear disk brakes, mini cooper + subaru front brakes rear sway bar
The problem is that there is a metal sleeve inside the rubber. The bolt goes through the sleeve. What happens is it is rusted to the sleeve so when rotating the bolt the sleeve is trying to rotate in the rubber.
What will happen if forced is the sleeve will break loose from the rubber and then the bolt won't come loose from the sleeve.
Usually fixing this involves cutting the strut free from the rubber and removing it. Then you have to cut away at the rubber to get to the sleeve. Then you can slice the sleeve open to free the bolt.
It's not real fun to do and the rubber tends to burn and smoke real bad (due to the heat of the cutter OR from a torch). I envy those who live in rust-free areas.
I have a pair of brand new struts for the rear of my Festiva sitting in my trunk because of this issue. I haven't had the facilities to mess with it.
I'm having this issue and I don't want to replace the struts if I don't have to.. what is meant by this? there is no way to get at the bolt from the backside and I've already broken another craftsman screwdriver on this.Originally posted by r34king View PostUse a hammer and a punch to get the bolt out. I do it almost daily at work. Worst case get a new bolt for when you.put the kybs back in
Sent from my GT-I9000 using TapatalkLast edited by zoom zoom; 03-07-2012, 06:45 PM.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
