Originally posted by georgeb
New Member / Need help
Looked in my '92 wiring manual. Only 3 grounds under dash. One is radio and has eyelet/screw. Another with eyelet/screw is under drivers side near bunch of connectors. Last is 6-gang connector that has one wire going to ground (but not directly). Hope this helps.
You know, it's a real pain when blown fuses look perfectly fine...
...walks away with tail between legs
Thanks for all your help.72 Gran Torino Sport, 351 Cleveland, 4 Speed
72 Mercury Marquis coupe, 429
65 Mustang coupe, 289 automatic
66 Cadillac Calais
98 Dodge Ram 1500
91 Ford Festiva
Lol best way to test fuses is with a multi-meter, that way you know 100% if they're good or not lol
Originally posted by guilf1 View PostYou know, it's a real pain when blown fuses look perfectly fine...
Thanks for all your help.An idea can turn to dust or magic, depending on the talent that rubs against it.
Thanks for all your help.Originally posted by sc72 View PostHey, chin up, you think your the only one on here that has had a Duh moment, glad you found the problem and welcome to the site.
I can't find the post where he confessed that he discovered the cause of the problem, and I seem to have forgotten his name too.....probably the kinda guy who can't even identify his sparkle plugs, much less change them.Last edited by TominMO; 02-22-2012, 10:39 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Ok, since identifying the blown fuse, I replaced it. Everything worked fine for a week. Fuse blew again. Replaced it, and blew 2 minutes later.
This would be the 10 amp blade fuse in dash that controls signals, tach, gas and temp gauges, etc. Any ideas where to start? I'm definitely not an electrician...
Thanks yet again.72 Gran Torino Sport, 351 Cleveland, 4 Speed
66 Cadillac Calais
98 Dodge Ram 1500
91 Ford Festiva
The 10A METER fuse runs the backup lights, timer/buzzer, seat belts, signals, inst cluster illum, and cooling fan relay. See if it blows with all of those things off. If it does, there is a short to ground in one or more of the bk/y wires running from the fuse box to the switch for those components. If it doesn't blow, turn on one component at a time to check for a short in that circuit.
Hmm... I seem to recall it blowing when I put the thing in reverse. Not sure it was everytime though. I will check these things as you said. Thanks!72 Gran Torino Sport, 351 Cleveland, 4 Speed
66 Cadillac Calais
98 Dodge Ram 1500
91 Ford Festiva
When you play you pay I think is how that goes, Out having fun
and 2 days later the funny noises are louder so I took a look, this
is right next to my reverse switch, If you like to have fun too take a look!
^^lol i like to have fun too but my festiva does not go off road :lol: I'll get other toys to go off road with
i had the same problem it is a 10 amp fuse;
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
No, i havent had a chance to get under it, but the fuse blows every time i put it in reverse. Ive just resorted to pulling the fuse out when i go backwards. I'll have to fix it before inspection time though.72 Gran Torino Sport, 351 Cleveland, 4 Speed
66 Cadillac Calais
98 Dodge Ram 1500
91 Ford Festiva
