Hi Everyone,
So Last week Wednesday I went to take out both cv axles and replace them as they were making some bad noises. So I took them out of the hubs and with about 10 minutes of prying the drive side came out. Well the passenger side just wouldn't come out. I tried, and tried, and tried, and tried and I had 2 other friends trying as well. It was in there for good. So what do you do when you need your car back together but don't want to replace your transmission? Here is what I did, and I hope it helps others as well.
I started by removing the inner axle boot. From there I removed the clip holding the axle in inside the cup. I then cleaned out all of the grease within the inner cup. From there I put in some new grease and inserted the new axle minus that cup. I then put the boot back on and re-secured it. So far so good with doing that. I am aware that doing this isn't the best idea, but it worked and if we pried anymore on that tranny it would crack.
So I hope this helps as an option for those with the same difficulty. This is obviously not a first choice option, but it does work.
