Originally posted by bravekozak
to be. Some 2nd time replaced shafts will displace a snap ring. The snap ring
will have to be sheared by the side gear splines before the axle shaft can
be removed. The proper method ( your suggestion ) will be exhausted
without result before recognizing the snap ring has got you ! At this point
You use the brute force methods needed to shear the snap ring.
Good point though, no need to bring the big guns unless needed!
