After ordering and attempting to install the XTD stage 3 clutch, I find that none of the holes line up. I oval/slot the dowel pin holes, mark redrill and tap the new pressure plate holes. Install into vehicle, and now it doesn't disengage... Any ideas?
Rio clutch doesn't fit F-series flywheel
Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig -
It's not a G either, I have a spare G flywheel and disk, was smaller. Same size disk as the F, just a tiny bit bigger overall pressure plate.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
Hhhmmmm that's funny.1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
I'll see if my e series clutches fit tomorrow..I didn't even think about trying it lol..2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
^ it will be Smaller.1992 white L, Bp, American racing 13's, stock trans.
The disk is right, the pressure plate just doesn't line up for anything. I'm guessing the raises surface that the stock clutch rides on needs machined flat.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
Dennis
88 Dakota tow pig
Any ideas?Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
Everything on mine bolted in perfectly . I even have an f series flywheel and my old Rio clutch and they bolt together just fine ,my guess is that clutch you got is wrong model . Since u have gone this far with it I would have the lip shaved off and pray that its balanced as a pack ... Good luck .New build on the way .
I got it perfecly centered, it did rub something inside bell housing, but it stopped making noise very quickly, so it couldn't have much in the way.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
Maybe thbigger pressure plate?? You got it apart again yet to see?1992 white L, Bp, American racing 13's, stock trans.
Ran out of time in the shop, have to wait till Monday night.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
Well I took the clutch and pressure plate off the vehicle and reassembled them. Placed them on the press with a spare t/o bearing and lightly applied pressure to simulate pressing the clutch pedal. After less than a 1/8 inch of movement the disk was moveable. Now I really have no clue how to make it work.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
are you sure the t/o bearing is contacting the pressure plate when it's all mounted?2008 Kia Rio- new beater
