Yes, but the sleave it slides on isn't really that long. I maxed out the arm and I can see on the inside of the pressure plate fingers where they touched the disk while it was running. I'm just not sure why it wouldn't free spin inside the assemble with the pedal depressed.
Rio clutch doesn't fit F-series flywheel
Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
Originally posted by gauge_half_inch View PostAny ideas?Some people like to read fiction,I prefer to read repair manuals. Weird I know-
I just happen to have a spare cable F laying around. Unfortunately I'm missing the t/o bearing(its in 91Mcnastys car) so this isn't really accurate, but I slid the flywheel/disk/pressure plate assembly onto the input shaft to the approximate location according to the dirt ring inside the dirty bellhousing. I moved the cable lever to the approximate limit, before it got there, the release fork actually hit the fingers of the pressure plate. What am I missing? from what I saw by doing that, with a t/o bearing in place, it should have dissengaged the clutch with the amount of movement it too on the press, with the amount of travel left on the cable lever travel.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
Maybe the TO bearing is the wrong thickness? Jus thinking out loud.I see that the Kia 2002 rio to bearing is .8385 face to face. But cant find anything on a f series for this dimension.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
I have about 5 flywheels laying around or in use, that's not my issue.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
I'll probably be pulling my bp/f out this weekend so I could get the part number off of it and run it down to you. Gotta bring back your tow bar anyways!!1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
Any luck yet Dennis?Some people like to read fiction,I prefer to read repair manuals. Weird I know-
No time. Yet. Need to get a spare t/o bearing to do a full mock up.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
Originally posted by 91mcnasty View PostI'll probably be pulling my bp/f out this weekend so I could get the part number off of it and run it down to you. Gotta bring back your tow bar anyways!!Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
Ok thanks for that, I'll ge tyou that t/o bearing soon so you can make some progress!1992 white L, Bp, American racing 13's, stock trans.
Do what you can, don't put yourself in a bind. It's gonna be a little bit before I can try to reinstall it.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
