If I manage to get the ac working on the aspire I thinking about seeing if I could adapt a cabin filter to the system. Since I run the outside air most of the time it would probably cut down on dust quite a bit. I haven't stood on my head to investigate the inside system but I know where the inlet is. I thought about cutting a foam filter and sticking it in the inlet. Anybody else thought about installing a cabin filter?
Cabin filters
You know, on the Festiva, there is a filter for the cabin recirc air. Now that you mention it, I don't recall one for fresh air. Guess they have me figured out - air is much dirtier inside
ops:
That being said, the recirc air filter is dang near impossible to get to without dash removal. I agree it sounds like a good idea, and I would imagine the blower could handle it - it already has one filter.
jeff
G-man, I haven't seen a dual fan on any Ford, Lincoln, Mercury, Mazda or Toyota without dual climate control. And then, the second fan (blower) is only to control the air volume to the passenger, or rear passengers.Originally posted by mechanicaldjor very reduced airflow
our blower units are located in the drivers side center of the dash and the intake is on the far right side of the dash and plus we have a single squirrel cage fan, not a dual like most cars
and no, it won't burn up the motor. Only stalling the fan or completely eliminating all air flow would do that.Jim DeAngelis
Do not use the defrost with cold air!! It'll choke the blower and you can only restart the blower motor with s very sophisticated tool, like a hammer.Originally posted by FB71Only stalling the fan or completely eliminating all air flow would do that.
I *think* most car cabin filters are trimmed to size cheap furnace filters marked up 4000%I will NOT drive a minivan
Cabin air filter on my Taurus is same material as the engine air filter,, after approx 100k miles I did notice an airflow restriction... removing and shaking/banging/vacuuming the filter clean saved me $10 for the replacement.. I personally don't see them as a great value as I don't have allergies.. compared to another car I drive regularly with the windows open I can see they cut down on dust and pollen somewhat however.
the OEM filters are like whats in good vacuum cleaners, a HEPA filter. Most aftermarkets are whatever they can find cheap.Originally posted by HappyMomDo not use the defrost with cold air!! It'll choke the blower and you can only restart the blower motor with s very sophisticated tool, like a hammer.Originally posted by FB71Only stalling the fan or completely eliminating all air flow would do that.
I *think* most car cabin filters are trimmed to size cheap furnace filters marked up 4000%Jim DeAngelis
