Rebuilding Carb
  • Rebuilding Carb
    Yarded off the carb and ordered a rebuild kit for it. Any advice before I tear into this rats nest?
    "Performance over Comfort"
    88 LX with 1.3 Liters of FURY......And a dent in the fender.....
    Before there were computers, there were vacuum lines
    Lots and lots of pictures, at every step.
      Air compressor is essential.
        if you need expert advice ask jay(kartracer46)
        Never Hire a Boy to do a Man's Job!!
          rebuilding carb
          id soak the whole carb in carb cleaner [ive used lacquer thinner,as well] soak it awhile,or take it apart first,then soak the parts. ive always ,just bought a rebuilt carb.some of the emulsion tubes ,are solid,with crud. i admire your courage.
            10X
            He is the guru of carbies!
              well movin is sharp too and he is on often.
              91 Festiva GL "Scrat"
              82 Honda Goldwing GL1100i
              85 BMW 535is "Brunhild"
                Movin does lots of different kinds, Kart has lots of experience with these
                unique little carbies..
                Forest grove gets a horrible mix of Portland air and Newport air and wyndie
                roads down the little Nestucca can twist a carbie into an aluminum pretzel
                But the trip To Kiwanda and the Pelican is worth it! Storm watch...
