Yarded off the carb and ordered a rebuild kit for it. Any advice before I tear into this rats nest?
Rebuilding Carb
rebuilding carb
id soak the whole carb in carb cleaner [ive used lacquer thinner,as well] soak it awhile,or take it apart first,then soak the parts. ive always ,just bought a rebuilt carb.some of the emulsion tubes ,are solid,with crud. i admire your courage.
10XOriginally posted by kumalaba View Postif you need expert advice ask jay(kartracer46)
He is the guru of carbies!'93 Blue 5spd 230K(down for clutch and overall maintanence)
Movin does lots of different kinds, Kart has lots of experience with these
unique little carbies..
Forest grove gets a horrible mix of Portland air and Newport air and wyndie
roads down the little Nestucca can twist a carbie into an aluminum pretzel
But the trip To Kiwanda and the Pelican is worth it! Storm watch...
