bought non running festiva .was origially an auto trans.dropped moter and 5 speed with harness from another running vehicle.have issues with the fuel pump not responding properly.replaced fuel pump and resister under dash.with key in on position the fuel pump will push fuel but continue running.turned key off and back on and fuel pump would not come back on.i have power to resister under dash.when i touch test light on another back probe fuel pump kicks back on.i think something is very wrong somewhere in the wiring.been trying to figure this out non stop for the past week.help please
93 festiva project
Originally posted by jfd64 View Postok the relay .the fuel pump should come on for a couple of secants give pressure and then shut off with key in on position.
Actually, georgeb, I think he is correct.
I replaced the OEM pump with a Advanced Auto unit which was loud enough that you could hear it when it ran, before you started the car. So you could hear it run a few seconds when in "run", then shut off.
I also agree with you that without the micro switch engaged at the VAF or jumpered, it will not continue to pump more than about 3 secs. Which is probably how long it pumps with the key in the "run" position.'93 Blue 5spd 230K(down for clutch and overall maintanence)
My '92 pump is uncovered because I'm investigating a fuel delivery problem. I went out there and turned the key and heard nothing. I jumped it yesterday so I know what it sounds like. I'm certain that is does not momentarily run when you turn the key like it does on most cars. Plus there has been much discussion of the issue on this site. I wish it did to make it easier to diagnose a no-start situation!
not sure whose opinion is right on weather fuel pump should shut off or not yet.repair manual says it should.anyway their seems to be some advise floating on the wiring that i currently have in vehicle.the car had an auto trans that had been removed.i place moter and 5 speed in.wiring harness on moter from vehicle of same year with 5 speed manual trans.should i also change the wiring that runs under left front fender?computer?under dash wiring?going with manual trans must i delete ac?lots of question at once .i appreciate your help since i have gotten myself over my head on this project.hopefully what i learn will have value now and in future.
Georgb and I have differing observations, I do not think these are opinions.
No, the wiring and computer do not have to be changed with this swap.
The transmission is NOT controlled by the ECU.
No, you do not have to lose the AC.
But you can send it to me, if it is in your way!
"anyway their seems to be some advise floating on the wiring that i currently have in vehicle."
I have no idea what your say in the sentence above.
Please clarify.
Only real issue is the sensors on the transmission that need to be wired in properly.
Again, please put your location in your profile some maybe be close by and can give you a hand.Last edited by Pu241; 03-13-2012, 02:41 PM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Originally posted by jfd64 View Posti have gotten myself over my head on this project.hopefully what i learn will have value now and in future.In love with a MadScientist!:thumbright:
So what is the status right now? All wires and lines hooked up but no start? Fuel lines not backwards? (common problem). Make sure hose coming from filter goes to rail, not fuel press regulator. Car will not stay running without intake hose attached. If car starts on ether, you have fuel prob.
didnt get an opertunity to work on today.went to junk yard and found relay for 5 bucks instead of 90.00 at store.intake is not attatched.ist thing tomorrow it will be.would go out and do now but gotta keep wife from getting annoyed with projects.thanks for advise
got it running this morning.it was the intake air hose not hooked up.10 minutes to hook up and she lives.spent most of my time for a week trying to figure this out .ignorance has not been bliss.thankyou very much.pretty exited right now got a lot to do before it is road ready,rear axle and front hubs are converted over to an aspire.was able to find complete set of like new wheels and tires at junkyard cheap
