i'll try and explain it better.
i unpluged the clutch engage switch and tested both prongs for an ohm reading and it tested zero. my husband pressed on the clutch and it still read zero.
i then used a no. 10 wire with connectors on the ends, slide one over each prong making a loop. tried to start it.. same result. no change on the starting. it still starts with the remote.
am i doing something wrong?
the other end of the switch goes up into the wire harness under the dash. i am testing the one hanging from the clutch switch.
