lower control arm nut and bolt
  • lower control arm nut and bolt
    Well I've changed the lower control arm and tie rod end on the passenger side without a problem now I am doing the driver side and have problem. The captive nut that is in the frame is turning I can't tighten or loosen the bolt.
    If its going to involve having it towed to a body shop and frame cut and rewelded I'll just junk the car and remove the new struts, and exhaust that I put on.
    Any other ideas?
    Early 99 F350 ex. cab longbox Powerstroke 6 spd, manual tranfer case and hubs 190k
    2009 ford flex
    2002 ford Ranger 4.0l, 6" lift, 35x12.50x15 super swampers
    1994 F150 4.9l, 5spd, 2wd
    1988 Festiva 1.3l, 4 spd, 184k
    Try wedging a piece of flat steel between the nut, which is square and will grab better than a hex, and the frame. The nut is toward the outside of the channel. You can make a couple cuts from the hole and bend down the channel to get better access. I ended up cutting my bolt but I wish I tried this first.
      Go in with a small hole saw thru the side or bottom of the frame horn near the nut, cut the bolt with a sawsall, get the old nut out thru the hole, get a longer high grade bolt, get a new high grade nut, put nut with a washer glued to it in a box end wrench and stick it in thru the hole you cut, etc, etc.
        That's the most creative i have heard yet...
        I had this happen to me the other day... And one of the cross member bolts did the same thing...
        Facebook Me!
          I think you can cut and grind off the head and knock the stub out all from the outside.
            Ya I just ended up doing this same thing last weekend to mine.... The lower control arm is a pain in the butt.... Hate rust so bad and every nut I toke off I had to brake off.
            1991 Auto Ford Festiva " Noel " <-- cuz theres No L in Festiva
            1991 Manual Ford Festiva
            1999 ford f-250 5.4L My gas guzzler.
              Thanks for words of encourgement. You saved a Festy from the salvage yard. I hear ya, only on my festy its either really rusty or really greasy from the oil leaks.
              Now if I could find a complete latch assembly for the lift gate I would have it made.
              2009 ford flex
                If you can't trap the nut this would be my next option.
