Well I've changed the lower control arm and tie rod end on the passenger side without a problem now I am doing the driver side and have problem. The captive nut that is in the frame is turning I can't tighten or loosen the bolt.
If its going to involve having it towed to a body shop and frame cut and rewelded I'll just junk the car and remove the new struts, and exhaust that I put on.
Any other ideas?
Any other ideas?
