IT LIVES! but the crankshaft pully wobbles like crazy! now what?
IT LIVES! but the crankshaft pully wobbles like crazy! no what?
i put the glass in(which has nothing to do with anything) and turn the key and it fired up and ran....but my crankshaft pully is wobbling like crazy so i shut the motor off. hmmm now what? it also dies when i try to go in 1st gear.
btw my W does work some times, so the post is supposed to say now what, not no what.1995 jeep Grand Cherokee
1993 Festiva L
I can't remember but isn't there a notch down there the pulley fits on? If it's not ligned up then it would wobble for sure. Anyway, you can remove the sparkplugs, take the car out of gear, and turn the engine over by hand to examine the wobble more closely. Good luck.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Drop the motor a little on the pulley side by loosening the three 17mm nuts on the motor mount. Remove the splash shield from the wheel well. Check the 4 small bolts. The big bolt is 21mm. I tighten mine with an impact but there are more accurate (difficult) ways.
Mine wobble to but only a little like the pulley is worped;
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
Its the harmonic balance it will shake a little;
'92 Festiva L M/T
'93 Festiva GL A/T
No we dont have emOriginally posted by mattrhodes850 View PostIts the harmonic balance it will shake a littleSome people like to read fiction,I prefer to read repair manuals. Weird I know-
^^ nitto is right, our whoppign 63 hp didn't require one must be. Aspires are the same way. Being a 93, he should have a large nose, make sure the locating pin is in the correct hole and make sure the pulleys are on straight. I had one that wobbled on an aspire. The guy had it on crooked. Loosened the 4 10mm bolts and re-seated it and tightened in a crossing pattern and that took care of it.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
