no running lights?
  • no running lights?
    have a 91 fest all the lights work except the running lights, bulbs are good, is this a relay or a switch that would cause this?
    I believe there is only a relay under the dash and a module on the firewall that control the daytime running lights
      i tried the switch by the steering wheel, still didnt cure it. not getting any power to fuse.
        Looks like it is time for wire chasing. Get yourself a good volt meter and test light and start checking wires. I had to reconnect a broken wire to get my parking lights working. Do your dash and cluster lights light up or don't they work either.
        93 Festiva L White B6T
        99 Dodge Ram STL Green Cummins. AKA the Jolly Green Giant
        89 Festiva Blue
        91 Green “Mad Maxine” Festiva B6T
        93 Festiva GL Black BP automatic
        93 Festiva GL Green stock
          the dash lights dont work either would this be a relay? getting power on both sides of all fuse links
            It might be a broken wire behind the fuse box. Or down by the drivers side kick panel. I had to soder whires together in these spots. Fixed my problem. Just have to look at the wires closely.
            89 Festiva Blue
              Where are you located. Maybe someone is close to you to help you out.
              89 Festiva Blue
                Canadian model? 92 manual says: Check rear wiper fuse, running light relay. There's also a running light module to check but only if the DRLs won't turn off. The relay is the front one of three behind the dr side headlight according to my pic.
