Motor/Transmission Mount Location
  • Motor/Transmission Mount Location
    Ive done a search but couldn't come up with anything that helped so i've added a picture to be more precise. I've been looking underneath the car and cant seem to find where this mount is located? Any ideas on how to replace it? Ive already replaced the other two mounts. Thanks for helping.
    Its in on the tranmission. Toward the back. Be careful to make sure yout current bolt fit the new MM tread.
    91 Festiva, BP, auto
    69 Mercury Cyclone CJ, 428 SCJ, 4 spd
      It connects the Trans to the crossmember in the rear of the trans
      -M3NTAL MARK! Woo!!
        That picture is upside down also. The stud goes through the crossmember.
        The Festiva Store
          Those are the weak ones..nobody on the west 1/2 of the US carries them.
          The nut for the stud is inside a hole in the crossmember. The other two
          bolts are through the trans bell housing, close to the rack and pinion.
            cool thanks for the info ill be looking for it tomorrow
              How did you know it was bad if you can't find it?
                engine shakes when starting off in 1st gear. I just went ahead and decided to change all of the mounts. i pulled them all off and they all had cracks in the rubber. After replacing the other two mounts the vibrations went away.
                  It's there but hard to see, especially if your laying on your back in the driveway.
                  That front to back cross member hides it pretty good.
                    I can see mine real good from top
                    www.facebook.com/rhodestiva ;
                    rhodestiva@gmail.com ;
                    '92 Festiva L M/T
                    '93 Festiva GL A/T
                      Here are some pics from the recent fuel/brake line job I did.
                      Rear mount (one you have in your pic)
                      Front mount
                      Festivame
