Alright as you can see by the horrible pic below that my car is leaking oil.......BAD! I am going to replace pretty much every gasket that I can get my hands on including the cam seal and crank seal. My problem is I cannot find all of the bolts that hold the bottom TBC?! It is caked with oil but I have pulled off everything I can find, the left side is loose but the right side is really tight. I've only pulled 2 bolts so far and the manual says 3 but doesn't really show them on the image. Any help is greatly appreciated!
