Anyone have a recomendation for a complete rebuild gasket set? I would like to get a full set.And just keep the stuff I dont need.
Engine gasket set
Engine gasket set
Tags: None
Does the re ring kits on rockauto come with top end gaskets?2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Im looking for "Personal preference from experience". ie You bought the gasket kit,and you like the quality. Or you bought the gasket kit,and it has poor quality. I know about RA & Chibay. Thx-Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Bump, somebody has to have a favorite one.....Some people like to read fiction,I prefer to read repair manuals. Weird I know-
I always buy Fel-Pro. I've used them for years with zero service issues. The only time I stray away from Fel-Pro is if it's for a car running boost or nitrous, then I usually go with a Cometic head gasket. Other than that it's Fel-Pro all the way. I've found on the Mazda motors that you'll typically come out cheaper buying just the gaskets you need rather than the full set.
X2 on the pieceing together the kit you need, just stick with Fel-Pro and your good.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
Originally posted by PhoenixSHO View PostI dont know if it applies for the festy , but generally , Felpro stuff is good.
And go rockauto before ebay.Originally posted by Zanzer View PostI always buy Fel-Pro. I've used them for years with zero service issues. The only time I stray away from Fel-Pro is if it's for a car running boost or nitrous, then I usually go with a Cometic head gasket. Other than that it's Fel-Pro all the way. I've found on the Mazda motors that you'll typically come out cheaper buying just the gaskets you need rather than the full set.Thanks a bunch guys! I'm gonna heed your advice with the Felpro. And since I'm working on two engines. I might buy one complete set. Then piece meal the other gaskets. That way I should have the o rings & misc small stuff if I need it. Thanks againOriginally posted by gauge_half_inch View PostX2 on the pieceing together the kit you need, just stick with Fel-Pro and your good.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
To my knowledge Fel Pro doesn't offer a full kit. I've searched every catalog I could find looking for a part number or listing with no luck. What they offer is a head gasket set with all of the top end gaskets for ~$100 and whats called a conversion gasket set that has all of the bottom end gaskets for ~$50. If you buy just the gaskets you need it should be around $90-$100 for everything depending on which engine you have.
What are the engines you're rebuilding?Last edited by Zanzer; 04-07-2012, 08:02 PM.
LOL,I just found this out. Looks like DNJ is the only one who makes a complete set. I'm working on 94 Aspire 1.3L. Does the conversion have the water/oil pump gaskets? Becasue I already have Cam,Dizzy,Valve cover seals. I saw that "Conversion set",and just blew past it cuz I didnt know what it meant.Originally posted by Zanzer View PostTo my knowledge Fel Pro doesn't offer a full kit. I've searched every catalog I could find looking for a part number or listing with no luck. What they offer is a head gasket set with all of the top end gaskets for ~$100 and whats called a conversion gasket set that has all of the bottom end gaskets for ~$50. If you buy just the gaskets you need it should be around $90-$100 for everything depending on which engine you have.
What are the engines you're rebuilding?Some people like to read fiction,I prefer to read repair manuals. Weird I know-
The conversion set does come with the water pump and oil pump gaskets but you also get a water pump gasket with a new water pump (which I highly recommend installing if you're doing a rebuild). Also, you get the oil pump and pickup tube gaskets when you purchase the front crankshaft seal kit..which is only $8 for that engine
Do you see a Aspire Conversion PN? I see the Festy not the Aspire.Originally posted by Zanzer View PostThe conversion set does come with the water pump and oil pump gaskets but you also get a water pump gasket with a new water pump (which I highly recommend installing if you're doing a rebuild). Also, you get the oil pump and pickup tube gaskets when you purchase the front crankshaft seal kit..which is only $8 for that engine
Muchas gracias amigo
