Did you disconnect the battery to set the computer back to factory settings? It will then build up new settings based on your individual engine performance. If you didn't clear the settings, as pointed out it's probably using the settings that were built up with the old O2 sensor. It takes about 20 miles of driving to build up new settings. It may correct itself or maybe needs to be cleared. Might help. Can't hurt.
__________________
__________________
