hi all! so i bought a 93 festiva L for 50 bucks. i am now at a point were i need help from all you, already did it people. it runs and drives! yay!!! but still has some problems. maybe someone knows. first of all there is a clicking sound that gets higher when i rev the engine.( by the way there is a ford festiva almost complete @ pickin pull i can take the whole engine from minus the throttle body and valvue cover and what cosmetic parts i havent took off a 1990 l plus, efi, auto the engine is 130 to 150 bucks.). second the drivers side wheel is bowed out on the bottom and my axel boot is streched, but all is tight and there, so i dont know why. and were in the hell do you fill up the manual transmission fluid? thtas it for now, i fix a lot already mostlly thanks to this form and my dad the mechanic.
my 93 festiva project car runs and drives now but...
The speedo cable pulls out to refill tranny fluidLast edited by Damkid; 04-07-2012, 07:15 PM.
Unscrew the speedo cable by hand and pull it out of the trans. Get a 10mm socket and about 2 feet worth of extensions and remove the bolt next to the speedo drive. Twist the drive out of the trans. The drive is also a dipstick. Use a long funnel and fill it to about an inch from the top. Check it with full mark on drive. Careful prying on drive as the tab is fragile.
