1988 Festiva Engine Fuse Problem
  • 1988 Festiva Engine Fuse Problem
    My 1988 Festiva has a problem with the 10 AMP engine fuse blowing randomly. At first, I thought it was a problem with the little black and white wire that comes from the fuse since it was melted. I put in a new fuse and I drove it around for an hour yesterday, and it drove fine. I routinely check the wire to see if it was getting hot, it wasn't, and I checked the fuse to see any evidence of melting, there was none. The bext morning, on the way to school, the fuse blew again. I not sure what I'm supposed to look for, so that's why I'm posting this
    Look around the engine for any bare spots on wires, any touching something hot
    especially look at the little wires behind the Alternator...and welcome!!
      Clarification, the "10 AMP engine" you refer to, where is it located (fuse box in cabin or under-hood)? It should be in the cabin fuse box as there should not be any 10 AMP fuses under the hood. The "little black and white wire" is a little confusing too. Anyway to get pics for us to help you?
        The 10 amp engine fuse is located in the fuse box in the cabin, next to the steering wheel
          Ill add some pictures of the damaged wire that comes from the engine fuse from the fuse box later on.
            That black/white wire goes to the alternator plug.
              Have you, by chance, recently swapped the alternator?
              1988 L - 232K miles Batstiva
              1989 L - 247K miles Slick
                no it has the same alternator
                  well i dont know how to upload images here, but theres a very thing wire from the engine fuse thats damaged, and it splits up into three identical wires, and when i look at the wireing diagram, i see components like egr sensor 1 and 2, map sensor etc. I suppose one of those things is shorting out, so i just have to find out which one it is.
                    The wire coming out of the engine fuse goes to: ECA, EFE heater relay, EGR solenoids 1 and 2, Self-test connector, PAC solenoid, electrical load control solenoid, purge control solenoid, alternator, MAP sensor, and feedback carb actuator. You have to unhook those things one at a time and bridge the fuse with a 10 amp ammeter. Trouble is some of those things probably only work at a certain engine temp. Lucky you!
                      Another option is to unhook all of the above and see if you still have a draw. Then you would need to replace the harness or find where it's grounded.
