so i finally got the motor running sound. i fixed my massive miss aligned front end. so i take it on the street for the first time(in years). i put it in 1st and it takes off slow and normal, then when i let off the clutch it jerks bad and starts to die, does this in second too. i got a new fuel pump but i'm wondering if i got the wrong fuel filter or something else. when its idling its smooth theres a little hesitation when i hit the gas but it goes away the warmer the engine gets. the check engine light is NOT on so no codes to check. i replaced just about everything for a car that been sitting, new fluids,new fuel pump, new spark plugs, wires, dist cap ect. VAF comes to mind, mine seems to be working right, i have another one thats like new but it needs soldering. i do have the haynes manual now but i cant seems to find this issue.
93 festiva surges / jerks when driving.
You sure the sock stayed on the new fuel pump? Sounds like its not getting steady fuel when your moving.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Mine did the same an the carb is bad.1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
Mine does the same thing only in first gear and if you change gears to early i think ir might be fuel filter. I knocked the guts out of my catalytic convertor and it helped a little there was a clog in it.
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2;
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
No. coil is good i think the fuel filter.
'92 Festiva L M/T
'93 Festiva GL A/T
Mine is doin the same been help.
'92 Festiva L M/T
'93 Festiva GL A/T
fuel filter won't affect a low speed load based hesitation unless it's so clogged that it's affecting rate of flow (unlikely).Originally posted by mattrhodes850 View PostNo. coil is good i think the fuel filter.
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2Trees aren't kind to me...
What could it be? any suggestions
'92 Festiva L M/T
'93 Festiva GL A/T
So it runs fine idling at high revs? It only misbehaves under load?
You might put the font end up on stands, start the engine, and put it in gear.Last edited by WmWatt; 05-21-2012, 07:38 AM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Yes
'92 Festiva L M/T
'93 Festiva GL A/T
