So I bit the bullet and bought a 1989 Festy, rough looking, has a bunch of mystery wires disconnected, and shakes at 50 mph, front tires are worn on the inside.
Fan would not come on, reason: Wasn't plugged in! Plugged in=works
Filled radiator with water, manifold waterfall effect, reason: Freeze plug missing!, plugged=holds water
Multiple coolant leaks at all hoses, fixed.
Mystery green wire, I believe it controls the fan operation. I believe it goes to the coolant temp sensor.
Single black wire coming off (spliced) the fan wire and going to my fuel pump, possibly hard wired or bypassed a relay or something. Gas gauge not working, possible sending unit or due to some bypassing or disconnected wire.
Mystery yellow wire, I believe it tells my temp gauge something, don't know where it goes to.
Wire coming out of the O2 Sensor at the manifold, I don't know where this goes.
Leaks tranny fluid, used stop leak, getting better.
It doesn't smoke, or use any motor oil, oil is dirty, needs changing.
