Originally posted by runner406
Short lived happyness
You shouldn't hear the fuel pump relay (it's under the dash) when you turn the key unless the self-test connector is jumped. It's probably the main relay (under the hood) you're hearing. Some of the info I put in post #12 is incorrect. if you hear the under-dash relay click, 12V should be going to the pump. The pump grounds through the inertia switch so make sure it is not popped. It's behind the drivers side rear panel. If you get a relay click and still no pump, the pump is probably bad. Before you buy a pump you can test for 12V at pump connector. There are 4 wires. I'll have to check manual for colors. If no relay click, relay or associated wiring is faulty. Never heard of this happening.
I have had the short harness on top of the gas tank go bad, but it was causing weird intermittent starting problems so it was really hard to hunt down. It is an uncommon problem but it can happen.The Festiva Store
^ +1
look for burnt or discolored connectors along that harness.Trees aren't kind to me...
^ specify what's above the brake booster please ShadeTrees aren't kind to me...
Runner, open the hatch and look under the speaker grille on the left side of the cargo area. There should be a cutout in the rear strut tower cover. There's a red button in there. That's the switch.Originally posted by runner406 View PostRed cut off switch ? Somebody take a pic of this i cant recall seeing that ?In love with a MadScientist!:thumbright:
Ok thanks tomorrow when i get home ill check it out for the red button idk why it woulda tripped tho it had a half tank of gas with my previous run ins with electric fuel pumps i never have any luck and always gotta replace them , i called my parts store a new one is 123.00 not to bad and then if it is actually that , ill have some kinda security knowing its new , when i open the lid to the fuel tank acess hole how hard is it to actually replace this little pump ?
The pump is pretty straight forward to replace. Once you get in to it, you shouldn't have much of a problem. All you need is a phillips screwdriver and a pair of pliers to get it out of the car.The Festiva Store
other side guy.... driverone and i both said DRIVER side... gotta pay attention when you're asking for info/advice.Trees aren't kind to me...
I just bought an Airtex 8023 for $26 on ebay. It had the wrong strainer but they refunded $12, the cost of the right one. There are plenty on ebay for under $30 with the right strainer. Make sure you remove gas cap or gas will run out of hose connection.
