O2 sensor hole repair
  • #16
    Pm'd for bung! :p
    Dan
    • #17
      How about brazing a thin layer of brass in the hole then tapping new threads?
      • #18
        How about adding a new bung on the other side of the pipe...
        Owner of:
        1991 Red Festiva L, 5 speed (Swagger Wagon)
        In progress:
        BP+G25MR swap, Kia rio axles hopefully.
        • #19
          Still would have to plug the hole that is there now. Double work. Also better access on the pass. side.
          • #20
            Even a stripe of brazing on the bottom side would work, and that plug chaser
            would fix the thread. That chaser is old ford plug thread and most other plug
            thread.
            A two wire O2 could be used with a ford plug helicoil and the ground ran to the head
            or any clean ground.
            • #21
              Weld, drill, tap. Or weld another bung over it. Won't make too much difference on a stockish car, the o2 has limited function anyway.
              • #22
                I've got my old aspire manifold if you want it, pretty sure it still has the o2 sensor in it, can be removed if you don't want it..your call, let me know.
                2008 Kia Rio- new beater
                1993 Festiva- Fiona, DD
                1997 Aspire- Babyspire, DD
                1994 Aspire - Project Kiazord
                1994 Aspire- Crustyspire, RIP
                • #23
                  Thanks, zoomx2. Going to the JY today to see if I can find a good one.
                  • #24
                    Went by the JY and got an Aspire manifold. Easy to get it off, since I had grabbed the downpipe from this particular car before. Two heat shield bolts rusted on, so I had to destroy the shield to get at the manifold-to-head bolts. But those came off really easily. And I have my old heat shield, which is good.
                    Before yanking it, first of course I checked the O2 sensor threads. The old O2 sensor came off really easily and the bung's threads were in good shape. $11 for the manifold; now just need the two gaskets.
                    BTW, the Fel-Pro #60286 fits the downpipe flange on all Festys, Aspires and 86-89 323s.
                    • #25
                      I was hoping you would figger a way to repair it versus replacing for those of us who despise dealing with junkyards.
                      • #26
                        ^ i like junk yards!
                        • #27
                          ^^^especially u pull its!!
                          • #28
                            A fairly easy swap then, and the best fix. Good deal too!
                            Dan
                            • #29
                              The JYs around here are pretty good. And for $11 (plus the $1 entry fee :-)) it's the cheapest fix available. Flange threads cleaned up well too!
