temp sender size
  • temp sender size
    can some one please tell me if there is different size temp sender size the reason i ask is i have a rebuilt head and when i went to put it all back together
    the temp sender would not fit from my old head it was to big, so do i need to tap this or find one in a junk yard that might work. one more thing my old head is from a 91 new head fit 89-97 not sure of the exact year it is from
    thanks to all that look
    The sensors should be the same for all years, I believe at least lol
    You sure you have the proper sensor?
      i think so all i did was pull it off the old head when the the old head was working it did show temp, by chance did the carb festiva have a different size? the reason i ask is when i looked at rock auto they show different part # that say for carb festiva from the pic it kinda looks smaller but then again could just be the pic lol
        I don't have much experience with carb'd festiva's but I always thought they were the same sized sensors, but like I said, I don't have enough experience with the carby's to know either way
          oh well just another reason to go to the jy and do a little digging around, thanks for your quick replays on this
            No prob, maybe someone else will chime in who knows a bit more about it and could help you out more
              I think there are 2 temp sensors, one for the radiator fan and one in the head for the temp gage. They are different sizes.
                yes you are correct the one in question is the one on the front of the head just to the left of the fan switch the temp sender for the temp gage is the one that wont fit
                  just got the new part in and yes there is two different sizes my old one looked like this
                  and the new one looks like this and is part number
                  Beck/Arnley 201-0916 Engine Coolant Temperature Sender
                    What is the word on the sender not being in contact with any water?
                    I changed my sender out last week, the engine/rad was full of water and yet nothing came out of the head when I removed the sender and the old sender was dry.
                    Am I missing something here??
                    1981 242 - Inge - Volvo. for life
                    2010 Edge - Vladimir - Ford. for the wife
                    2011 Focus SE - Noomi - Ford. for economy, comfort and dependability
                    And now...
                    1992 Festiva - Lil Chubby - Ford. it's just for racing...and it's not really mine...
                      I have found that there are 2 different sizes of temperature senders that I pulled from separate B3 heads (from the arrow).
                      I believe the larger thread, stubbier one is for EFI heads, and the smaller thread long skinny one is for carbed.
                      Just FYI
                      EDIT: to clarify, there is a SEPARATE coolant temperature sensor that threads into the coolant housing on the far right of this picture that is for the radiator fan.
                      -Aspire brake swap COMPLETE!
                        Dry sender.
                        Nlockage?
                        Maybe your thermostat is not opening?
                        Time to remove the thermostat housing and take a look.
                        Interesting problem.
                          There are definitely two different temp senders. I ran into that problem when I replaced my worn out carb engine with an Aspire engine years ago.
