So if it's not one thing it's another.. now my mazda try's to overheat, I say try because it doesn't actually go over the H mark, it hovers between half and the 1/8th mark below the H.
For anyone that doesn't know, the car has a long history.. I fixed it after it sat for 3 years, new fuel pump, new timing belt, new water pump, new radiator and fan, new thermostat, new plugs and wires, new caliper and replaced parts of the rear brake lines, new front bumper and headlights, new...
the last problem was it was throwing a couple codes, o2 sensor/misfire cyl 2, I replaced the injector on cyl 2 and it's running fine now, the codes went away on their own. Now about a month or so later it "trys" to overheat.
I start the car, let it run for a minute, and take off down the road, it warms up like usual and drives fine for a couple miles, then all of a sudden the temp gauge will shoot up to below the H mark while driving 55 mph, and stay there.
Any ideas? I was thinking head gasket, since it blows out white smoke until it warms up, but it quits blowing out smoke when it's warm, and there isn't any water in the oil. It uses about half a quart of oil a month, and has a small water leak somewhere still after I've replaced most of the water related components, and I can't see where it's leaking, not that I've really tried to find it or anything.
