My car was clicking when going around curves, my cousins s10 was popping really loud like in mcds parking lot, in slow motion turns, both instances were cured with new axels. The hub being hot is probably an unrelated problem, like a bad bearing, seized calipers, or brakes dragging. Check for the pad retainer clips next time you take the tire off, and make sure both tires spin freely.
Front end noise... Need a second opinion
2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
You shouldn't have to lossen any sway bar bushing to replace an axle. I did it by removing the bolts from the strut and the pinch bolt off the end of the lower control arm (next to the ball joint). You have to push down on the control arm. Well, yes, I also had to remove the nut from the end of the axle.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
