I'm replacing the rear brake lines. Looks like one of the factory lines is routed above the gas tank. Is it difficult to remove/replace? I'm guessing it is, but figure it won't hurt to ask.
Brake line question
it's the RR line i'm assuming you're refering to and that doesn't go above the tank so much as just above the tank seam. in either case, George is correct. also make sure the line is tucked up so that nothing can snag on it.Trees aren't kind to me...
If you get lazy mechanics to run new lines up in this neck of the woods (such as how most of my cars seem to arrive) the car will be a plumber's nightmare underneath. You can be a purist and re-route exact, or you can be polite and run them in a new but organized fashion, or you can merely do shortest A to B as seems to be prevalent.
I routed mine over the top. I seem to recall bypassing a clip on the driver's side attached to the body. I found it helped to open up the trap door to the fuel tank in the rear floorboards and pull the line into position through there.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
