Pissed off wheel bearing dealie
  • Pissed off wheel bearing dealie
    I just put new fron pass side wheel bearings on my car 25-70 miles ago cause they were wasted now that side is roaring and noisey again wtf i pressed them off and installed them the same way new seals and synthetic grease and here i go again with a roaring noise wtf any tricks with this ????
    Over torqued?
    Hodginsa - Photography - Cars, people, everything.
    Festy is For Sale...
      No not over torqued i just read the post above there was no spacer inbetween the inner and outter wheel bearings and when i pulled it apart the moron had the bearing in upside down and now i have to get a spacer seems to be ... Does anyone know where i can get a spacer or what the thickness is of the suspect missing spacer for the front wheel bearing ?
        the rotating torque should not increase more than 10 inch lbs from loose to tight
        for new bearings, no more than 8 inch lbs for used bearings.
        It should increase at least 5 inch lbs. This is an observation not a specification
        you can dial in your own preference.
        Rotating torque is an excellent way to verify that nothing went wrong
        using the factory method.
        edit: just saw above, there are many shims to fit your hub perfectly
        the best guess is to retrieve a remnant and mike it.
          I've never heard of rotating torque, would you mind going in a little more detail. Gonna google it now anyways but I always like other peoples interpretation.
          1991 blue L, 5 speed.
          1988 red L-plus-all stock.
            So theres a variable size differance in this spacer ? How the heck do i determine how big a spacer is needed ? Trust me theres no spacer in my car this is ,my issue any clue if local stores carry this spacer ? Specfic name ? Or jost wheel bearing spacer
              When the knuckle is first installed at the factory, they measure it and then install one of 22 (IIRC) different-sized spacers to get just the right fit for the bearings. Sounds like the installer before you left it out.
              Read this thread: http://www.fordfestiva.com/forums/sh...bearing+spacer
                Ok yep guy even had the inner bearing back wards , my question for this page would be what or how do i save this assembly ? I have tool makers at work where i work at how do i actually make a apporate spacer i dont wanna toss this out for a missing spacer
                  Great thread thanks for the info for the time being im gonna take a spindle off my parts car then fix this spindle with the kia shims 11-15 like the one guy on here did thank you everyone
                    You are working on a hub.
                    Spindles are on the rear.
                    The distinction becomes important when using the search function here.
                      You mean inch OUNCE,not pounds.
                        Make sure you keep the Hub with the preload spacer. The spacer is matched to the hub.
                          ok, one: how on gods green earth does one install a bearing backward!!??
                          and two: the spacer is matched to the KNUCKLE, not the hub. the hub has no machining spec other than the OD that should be a ~.003" interferance fit to the bearing ID.
                            Your best bet since there was no spacer would be to get another whole knuckle/hub assembly.
                            93 GL modyfied!!!
                            :fish:
                              agreed, I think he may want to locate a T87C-1104-B, Spacer Selection Tool and find out which one it needs. Then head to a MAZDA dealer and have the parts counter look them up for an 89 323 perhaps.
                              91 Festiva GL "Scrat"
                              82 Honda Goldwing GL1100i
                              85 BMW 535is "Brunhild"
