I just put new fron pass side wheel bearings on my car 25-70 miles ago cause they were wasted now that side is roaring and noisey again wtf i pressed them off and installed them the same way new seals and synthetic grease and here i go again with a roaring noise wtf any tricks with this ????
Pissed off wheel bearing dealie
No not over torqued i just read the post above there was no spacer inbetween the inner and outter wheel bearings and when i pulled it apart the moron had the bearing in upside down and now i have to get a spacer seems to be ... Does anyone know where i can get a spacer or what the thickness is of the suspect missing spacer for the front wheel bearing ?
the rotating torque should not increase more than 10 inch lbs from loose to tight
for new bearings, no more than 8 inch lbs for used bearings.
It should increase at least 5 inch lbs. This is an observation not a specification
you can dial in your own preference.
Rotating torque is an excellent way to verify that nothing went wrong
using the factory method.
edit: just saw above, there are many shims to fit your hub perfectly
the best guess is to retrieve a remnant and mike it.Last edited by Movin; 05-12-2012, 11:26 PM.Reflex paint by Langeman...Lifted...Tow Rig
I've never heard of rotating torque, would you mind going in a little more detail. Gonna google it now anyways but I always like other peoples interpretation.1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
So theres a variable size differance in this spacer ? How the heck do i determine how big a spacer is needed ? Trust me theres no spacer in my car this is ,my issue any clue if local stores carry this spacer ? Specfic name ? Or jost wheel bearing spacer
When the knuckle is first installed at the factory, they measure it and then install one of 22 (IIRC) different-sized spacers to get just the right fit for the bearings. Sounds like the installer before you left it out.
Read this thread: http://www.fordfestiva.com/forums/sh...bearing+spacerLast edited by TominMO; 05-12-2012, 11:57 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Ok yep guy even had the inner bearing back wards , my question for this page would be what or how do i save this assembly ? I have tool makers at work where i work at how do i actually make a apporate spacer i dont wanna toss this out for a missing spacer
You are working on a hub.
Spindles are on the rear.
The distinction becomes important when using the search function here.'93 Blue 5spd 230K(down for clutch and overall maintanence)
You mean inch OUNCE,not pounds.Originally posted by Movin View Postthe rotating torque should not increase more than 10 inch lbs from loose to tight
Make sure you keep the Hub with the preload spacer. The spacer is matched to the hub.Originally posted by runner406 View PostGreat thread thanks for the info for the time being im gonna take a spindle off my parts car then fix this spindle with the kia shims 11-15 like the one guy on here did thank you everyone
ok, one: how on gods green earth does one install a bearing backward!!??
and two: the spacer is matched to the KNUCKLE, not the hub. the hub has no machining spec other than the OD that should be a ~.003" interferance fit to the bearing ID.Trees aren't kind to me...
agreed, I think he may want to locate a T87C-1104-B, Spacer Selection Tool and find out which one it needs. Then head to a MAZDA dealer and have the parts counter look them up for an 89 323 perhaps.Originally posted by FestYboy View Postok, one: how on gods green earth does one install a bearing backward!!??
and two: the spacer is matched to the KNUCKLE, not the hub. the hub has no machining spec other than the OD that should be a ~.003" interferance fit to the bearing ID.91 Festiva GL "Scrat"
82 Honda Goldwing GL1100i
85 BMW 535is "Brunhild"
