Still weak spark at the coil wire?
Ignition / Key issues
The key is working because if it wasn't, you wouldn't get a bit of spark at all.
New coil.
New coil wire.
Solid 12V at coil
Still weak spark.
This needs some stewing...or a FestYboy!Contact me for information about Festiva Madness!
Going with this list, no you do not need the key part of the ignition switch replaced.Originally posted by timmytooth View PostTo answer an earlier question. I do have 12v on both sides of the coil. And still no spark... So to summerize I have replaced - Cap, rotor, plug wires, coil, battery, and ignition switch.
The igniter or ignition module and the pickup coil need tested.
First step would be to pull the disty and ground the housing, plug all
connectors in, position wire at coil tower for testing. Turn key on and spin
the disty shaft while keeping the housing grounded and staying clear
of the test area!!
What happens??
Note: Can someone find festYboys flowchart ??Last edited by Movin; 07-06-2012, 01:42 AM.Reflex paint by Langeman...Lifted...Tow Rig
Is there anybody that you can borrow a known good disty from? Switch it out and see if it runs.
IMO, it is the module inside the dist. and are availble on ebay, usually under $50.
Of course you could do what I did. Go to a pick it yourself junkyard, by a disty for $35.
It ran my Festy for 2 yrs until the engine said......Phffffttt!Dan
I need to remember that test. Arty has a flowchart?Originally posted by Movin View PostGoing with this list, no you do not need the key part of the ignition switch replaced.
of the test area!!
What happens??
Note: Can someone find festYboys flowchart ??Contact me for information about Festiva Madness!
Originally posted by scitzz View PostI need to remember that test. Arty has a flowchart?Post your Festiva or Aspire repair and maintenance issues. - USE THIS FORUM FOR ANY TECHNICAL RELATED POST (IE. How do I change my oil?, How to remove axle from tranny?, etc)
Yes, after we all asked he delivered!!!
Bad new parts strain my relationship with parts houses!!
Last edited by Movin; 07-31-2012, 10:16 AM.Reflex paint by Langeman...Lifted...Tow Rig
