So I'm switching out a harness I am about to the point of having everything done to pull it out. My questions is which direction is best for pulling it out. Pulling it into the cab through the firewall or pulling it out of the cab. Its shorter to pull it out but I don't see how the fusebox would fit through the firewall.
Wiring Harness removal
I did this just a couple weeks ago, I myself pulled the engine harness through the firewall into the interior, for myself either did not see how the fuse box would fit through the hole. It's really not hard to pull the rest through either, takes a little longer, but not very hard, also makes it easier having someone feed the wires through the hole while you grab them and pull.-Josh R
I'm not worried about this fusebox I am putting in another entire harness with fusebox.
Originally posted by bravekozak View PostIt's not that hard to pull it the other way. You don't want to cut all the fuse block wires. The potential for loose connections will increase significantly. Trust me.
