Right now I'm replacing the brakes on my 91' Festiva. Currently, I'm installing the calipers and pads. My Festy didn't have the shims that go behind the pads. My calipers and pads are assembled but they need the shims. After researching this forum I could not find the answer I wanted.
Looking at the caliper assembly, it seems as though the shims are definitely needed. There is too much play between the pads and caliper. I would believe that this would cause the pads to drag lightly and wear unevenly. Others on previous threads have stated they excluded the shims and they believed that the brakes were fine without them. I find this hard to believe. Am I able to purchase these shims? I haven't found a parts store around here that has them, nor have I found a local junkyard that has a Festiva.
Also, the calipers came with pin retainers and cotter pins. Are the cotter pins a better choice over the pin retainer? Thanks in advance.
