Carb disassembly help
  • Carb disassembly help
    Hey guys! I have an 88 with a stock feedback carb I am cleaning but I can't figure out how the fasteners that hold the choke thermostat ( as it's labeled in my carb kit guide ) work, anybody with experience know what I'm talking about and can point me in the right direction?
    Update: There are three of them by the way, I found the replacements for them in the carb kit, they look like little swords. I just can't figure out how to remove the old ones, they are hollow in the center with a small bit jammed in one end.
      You need a fine tipped rivet gun to install
      you need a drill to release the top cap.
      you need a roll pin punch that same
      diameter to drive out the shaft.
      If you do not have the rivet tool
      you may be able to borrow for
      free from the parts store that
      you got your kit, both AZ and
      Oreillys do this. You can chuck
      the rivets and use self tapping screws.
        Thanks for the info Movin! I got the rivet gun to install and managed to carefully wear the top off of the old ones with a philips screwdriver. Its all disassembled and soaking now
          mind snapping some pics?
          1991 blue L, 5 speed.
          1988 red L-plus-all stock.
            Heres pics, and new question.....the black piece in the second picture, my kit has two new gaskets for it..one on each side I assume, and looking closely it appears two have two old gaskets glued/burned on and they are super hard to remove. It says its a phenolic block so I am worried about hurting it, should I bother soaking/cutting them off with a razor etc and install the new ones or just plop it back in as is to avoid damage?
