Grinding noise
  • Grinding noise
    hey guys,
    straight to the point this is wat happens-
    I have a 1.3L manual festiva, now when the gear knob is in nuetral and u let the clutch out there is like a constant grinding sound, but when the clutch is bac in (in nutral) the sound goes a away???
    Iam lost plz help
    Ford Festiva 1992 Model, 1.3L 5 Door, Red, Mods- Roo-Bar with two spotlights, also stickers, on the bonnet, front window, and rear window
    sounds like the input shaft bearing is done
    you could have it rebuilt or just go and get a used one(cheaper)
      What and where do i find that?? Like any discription on how to replace it and where to find the part that needs replacing?
      Thanks
        sorry, i meant the input shaft inside your transmission and the bearing for it is broken
          Sounds like my problem...
          The only plus is if you got a 4 speed- now you can upgrade to a 5 speed!
          White '89L auto - Sold!
          Silver '06 Rav4, 95k!
