how do u,change an oil pump,on a 91 festy? the haynes manual,says u,dont pull the engine,just oil pan and front sprocket ? :cry_smile:drool:nono:
oil pump
I need to change one out as the mount for the timing belt tensioner is bad (its at an angle
Do these tend to go bad? Will one off an Aspire work?
I have a Ford manual, says crankshaft socket, oil pan, then pump. Pump bolts are 14-19 foot pounds. Inlet tube is 69-95 inch pounds. If you follow the sequence, they pulled the engine, but I think it could be done with it in.1963 Fairlane - future NSS drag car
Originally posted by windy1 View Posthow do u,change an oil pump,on a 91 festy? the haynes manual,says u,dont pull the engine,just oil pan and front sprocket ?You gonna race that thing?
you don't actually have to pull the oil pan, IIRC, but there are 2 or 4 bolts that go through the front of the pan, and a seal that's a pain to seat properly if you don't pull the pan. Up to you if you want to try it, but you'll likely end up pulling the pan, or at least lowering it.
The whole job shouldn't take more than a couple hours if you're experienced with that type of pump. The hardest part about it is setting the valve timing. As long as you're putting a new oil pump on, you might also change the timing belt tensioner, water pump, and belt, depending on their age.
Originally posted by Larry Hampton View PostI need to change one out as the mount for the timing belt tensioner is bad (its at an angle
Do these tend to go bad? Will one off an Aspire work?You gonna race that thing?
oil pump
i was going to replace oil pump ,when i replace pan gasket. engine has 165,000 miles. actually,if pump is good,and it seems ok,why should i replace it? i was going to,cause i have to do pan gasket. if pump works fine,why replace it? what u,guys think? thanks for great feedback,guys mdoyleufo@gmail.com
I say buy a brand new one and have a shop install it :p
Originally posted by windy1 View Posti was going to replace oil pump ,when i replace pan gasket. engine has 165,000 miles. actually,if pump is good,and it seems ok,why should i replace it? i was going to,cause i have to do pan gasket. if pump works fine,why replace it? what u,guys think? thanks for great feedback,guys mdoyleufo@gmail.com
If your oil pressure isn't low, I wouldn't bother replacing it. Same with the water pump. If your cooling system is functioning as expected, no reason to replace it (Unless there's marks around the weep hole, then the seals are bad.)
Timing belt, if it doesn't look stretched or damaged, I put it back on, don't even care about orientation. So on, so forth. I've reused gaskets without problems. Just inspect and test as much as you feel reasonable. You'll get a feel for what's generally in need of repair/replacement and what's not.
If your pressure is fine, leave it alone. This type of pump really doesn't wear out persay. If you were doing a rebuild after a bearing failure where large chunks of metal was getting sucked up, then replace it and dobt chance it. But as a maintenance part, save your money and just do the gasket.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
So you've no reason to replace it other than you feel like it might need it?
Leave it be. Do the timing belt/water pump if you're worried1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
Originally posted by Festy46 View PostI never saw any sitting at an angle....usually the pulley gets to feeling rough when you try to spin it or it may get kind of "growly". Aspire should fit just fine --- if you have a "big nose" crankshaft on your Festiva. If you have a "small nose" crankshaft, the Aspire oil pump will be way too big for your crankshaft.1963 Fairlane - future NSS drag car
