Wow! Seems like I've got quite a job ahead of me. I won't be able to work on the car until at least Tuesday. I'm heading to Manitoba for a few days and I don't want to start something I can't finish today. I don't have a garage and I have to do all my work on the driveway. I picked up a new gasket today and still have some packing to do 'coz I'm leaving first thing Sat. morning.
A few "replies" mentioned I may also have a ventilation problem. I did a bit of hunting around and I discovered leaks can be found by using throttle cleaner, propane gas, stethescope, and even water mist. Are any of these necessary for the problems I have with my car?
Movin you mentioned a baffel inside the valve cover. That must be the metal plate running from just beneath the oil filler cap to where the pvc plugs in. Is that cleaned while the vc is off. And if so how? You also mentioned that some tubes may be carboned up and need cleaning. Are they cleaned by jamming a small rag through them or by spaying a cleaner into them?
Thanks again everyone. I'll keep posting my progress.
