I recently replaced the cap, rotor, wires and 3 plugs on the Festiva.
The # 3 plug will not loosen. I was able to get it to turn tighter but not much. It will only move about 1/12 of a turn and no further. I tried working it back and fourth a lot and no more movement than 1/12 of a turn. I was afraid to turn to hard and strip the threads in the head. Car is running decent now so I stopped trying to get it out for now.
Any good ideas on how to get it to loosen while the head is on the engine. Don't see how any penetrating oil will make it into the threads with the gasket under the plug sealing against the head.
Festivame
PS I had the engine cold when I first tried it and also tried removing it when the engine was warm (not at full operating temp.)
Festivame
