For the fronts, the pins could still be sticking. Take them out, clean them smooth with sand paper or a wirewheel, and grease them and the sleeves they go into (pop the sleeves out of the caliper and grease them).
For the rear, the only thing I can think of is the (new) wheel cylinders sticking in the bores. Since there's almost no such thing as a "new" part anymore, it's actually possible, but highly unlikely that you'd get two faulty ones at the same time, or even in the same lifetime.
Did you replace the brake hardware in the rear? Is there a chance that you didn't get all the springs in the correct locations, or if they're old, that they're not capable of pulling the shoes back fully?
All those tests on the MC and booster passed, and you checked each bleeder for residual pressure, all that's left is physical parts being stuck/freezing up, etc.
