I am about to Change my CV axles the car is clicking pretty bad when i make turns, and i wanted to know while i have them out, is there anything else that i should just go ahead and replace?
CV Joint repair questions
just the seals in the tranny. How you going to change them?"FLTG4LIFE" @FINALLEVEL , "PBH"
Originally posted by Chobobulous View Post
and the seal I am talking about is the one that the axle passes through as it goes into the tranny."FLTG4LIFE" @FINALLEVEL , "PBH"
Originally posted by Chobobulous View PostThanks for that link, that is an awesome writeup....
there is no way the needed seal costs 40 dollars a piece though...."FLTG4LIFE" @FINALLEVEL , "PBH"
different seal...you need the axle seals"FLTG4LIFE" @FINALLEVEL , "PBH"
Originally posted by GenevaDirt View Post
Chob,they are right & left specific. You need two different seals fyiSome people like to read fiction,I prefer to read repair manuals. Weird I know-
Originally posted by nitrofarm View PostChob,they are right & left specific. You need two different seals fyi"FLTG4LIFE" @FINALLEVEL , "PBH"
Don't forget to put a basin under the transmission end of the axle to catch the transmission fluid which pours out when the axle is removed. Photos don't show replacing transmission fluid. Ask if you need info on that.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Originally posted by WmWatt View PostDon't forget to put a basin under the transmission end of the axle to catch the transmission fluid which pours out when the axle is removed. Photos don't show replacing transmission fluid. Ask if you need info on that."FLTG4LIFE" @FINALLEVEL , "PBH"
