Try turning your idle speed down a little
HHHEEELLLPPP!!!
it worsens when i turn it higher it helps but still does it;
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
it almost stalls when i turn it lower;
'92 Festiva L M/T
'93 Festiva GL A/T
i changed it too. but i am going to soak the iacv in some mmo .
Scitz told me about. i am trying it tomorrow after work.;
'92 Festiva L M/T
'93 Festiva GL A/T
Yea that's what it is. It will hold a high idle for a second then go down. Up. Down. Up.....;
'92 Festiva L M/T
'93 Festiva GL A/T
Your duct tape is leaking air somewhere-Greg
Redneck Engineer
FOTY - '09
^^X2.... That's why I try to fix things properly, it prevents further problems down the road
i its not leaking anywhere. i sprayed carberator cleaner all over and detected no leaks.
i will try clean the iacv again tomorrow;
'92 Festiva L M/T
'93 Festiva GL A/T
You are on the right track. The computer shuts the injectors off until it is happy
with the RPM, then turns the fuel on again. If it is rough when you slow the idle
it may have something else wrong too.Reflex paint by Langeman...Lifted...Tow Rig
stop.
can you still lift up on the pedal and the idle hunt stops? if so, you have to clean your throttle or adjust you TPS so that with the throttle plate closed, the ECU sees the idle signal from the TPS (TPS is a 3 position switch for the ECU: idle, run and WOT, and idle is a sensitive position and has to be set with a feeler gauge).
Clean the throttle first!! any debris that leaves the plate hang open can cause the TPS to be moved out of the idle position and cause hunting idle.Trees aren't kind to me...
I got some mmo and put a little in air hose goin to iacv seem to help. I will soak the iacv in it when I get home. The throttle body I cleaned well it looks really good on the Inside.;
'92 Festiva L M/T
'93 Festiva GL A/T
ok did the MMO thing and helped a little. it sounded good this morning but tomorrow is another day. the only way for it to sound best is put TPS screw all the way left and higher the idle screw adjustment has high idle sounds a little better and still get 40mph so i guess i will deal until i get my RPM gauge in. thanks for all the help.;
'92 Festiva L M/T
'93 Festiva GL A/T
Clean the throttle first!! any debris that leaves the plate hang open can cause the TPS to be moved out of the idle position and cause hunting idle.;
'92 Festiva L M/T
'93 Festiva GL A/T
