Approximately how long should It take me to remove the clutch pedal Assembly from my parts car & install it in my ATX car? Also will the cable clear the ATX Power Booster? It looks like its really a tight squeeze.Thanks for the input!
ATX to MTX
ATX to MTX
Last edited by nitrofarm; 06-30-2012, 08:51 AM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Fuseable Link Distribution Block repair linkTags: None
Festiva or Aspire? I know on the festy the cable clears no prob, Aspire I don't know since I've never done one. If the dash is out of both cars the pedal swap takes less than 30 mins. If not I can take anywhere from an hour to 3 hours depending on your experience level and how familiar you are with the setup.No festiva for me ATM...
Originally posted by htchbck View PostFestiva or Aspire? I know on the festy the cable clears no prob, Aspire I don't know since I've never done one. If the dash is out of both cars the pedal swap takes less than 30 mins. If not I can take anywhere from an hour to 3 hours depending on your experience level and how familiar you are with the setup.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
The festiva isn't too bad, I always unbolt the steering column and slide it up out of the way, sometimes I take it completely out. It makes working under the dash a lot easier. Can't say for sure if t has to be unbolted or not, because I've always done it. But then again all the ones I've done have been festiva so it might be different on the aspire but I'd imagine not too different anyway.No festiva for me ATM...
Ok thanks again for the input.I'll keep it in mind.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
