The original w/w pump quit so I picked up a couple from PnP today. When hooked directly to the battery both pumps work well.
Installed the first one and it worked when I tested it. Put everything back together (splash shield etc) and went for a drive. Tried the pump again and... nothing.
Took it all apart again and hooked the pump directly to the battery and it worked fine. Checked voltage going to the harness at the pump and there's just over 12 volts. Hook the pump back up to the harness and... nothing.
Any ideas on what to look for would be greatly appreciated.
Thanks
Ian
Sent from my SGH-I727R using Tapatalk 2
Thanks
Ian
