Originally posted by bravekozak
Stuck axle...
I have a hunch that it works in a similar manner to the way drdan does it. I may try it sometime if my method fails, but it rarely does...for me! YMMV.Contact me for information about Festiva Madness!
The important thing is to have back up methods if one does not work. Not all grooves
are as they were new, and reman shafts..you could have pretty messed up splines.
Dirt from failure, poor installation or lack of oil change can foul clip movement. Installation techniques that bend part of the clip back into the spline is a really fine
gift to leave for the next guy. The wrong kind of clip..a snap ring can cause the next
fine gentleman to spew filth not fit for any human to hear!! Don't toss the small maul
and chisel, your turn may come!!
You're running your axles without circlips? They will move in and out of the side gears during suspension extremes. Possibly out of the splines!Originally posted by denguy View PostI just did 2 axles. I had a 12" long piece of 1/2" x 1/2" steel bar stock that I ground a 30* angle on one face, about an inch back, to where it that end would just fit up between the axle and the trans case with the ground face against the case. On the driver's side I had to place a short 1/2" square piece up against the case under the bar for a fulcrum. One careful pop on the end of the bar with a small 3# sledge and out she comes. We shoved some 7/8" OD pvc pipe with some duct tape on the end into the each side gear to keep them in place in case the trans is turned. We put the axles back in without sirclips. Any guesses on why they are in there? I say, bottom line, it's to avoid sidegear issues during assembly line and future maintainence activities.
Makes really cool trails you can watch in your rear view mirror!! :eeeeeek:Originally posted by georgeb View PostYou're running your axles without circlips? They will move in and out of the side gears during suspension extremes. Possibly out of the splines!Reflex paint by Langeman...Lifted...Tow Rig
Bungee the heck out of it to hold it straight out lol yeah to your truck with the bungees
long enough to allow rotation of the axle then ding the bell, double rock with two
pry bars and grand finale the really big hammer!!Reflex paint by Langeman...Lifted...Tow Rig
I sat on the ground and put one foot against the frame then just turned and yanked until it came out. Like the man said, it's position rather than force that get's it out.
To put an axle back in line the gap in the circlip at the top. Don't know why that works but I read it and it does. Voodoo.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
I wish this statement was true for me, one of my side gears fell out last fall and I ended up having to pull the trans and rip it open to get everything back in place.Originally posted by Grey Vw View PostThe chance of the gear falling inside is pretty slim, just stuff a piece of cardboard. I've never had a gear fall inside and I've done it several times. And if it does fall it takes 10 minutes to reset them.2002 Ford Mustang GT Mineral Grey 5 spd
1996 Ford Explorer XLT AWD White POS
1992 Ford Festiva GL Metallic Blue 5 spd
is there any way to make a fork like object to go through the diff and around the pin in the diff so you could hammer on the cv shaft from the other side? i hope that made sense93 Festiva L White B6T
99 Dodge Ram STL Green Cummins. AKA the Jolly Green Giant
89 Festiva Blue
91 Green “Mad Maxine” Festiva B6T
93 Festiva GL Black BP automatic
93 Festiva GL Green stock
