Just stopped
  • Just stopped
    Need some help guys. My 89 carby just stopped today. It's getting fuel to the carby but not firing all it is doing is turning over. Any help would be grateful.
    89 Festiva L Plus Carby 4 speed "First Bite"
    02 Honda Odyssey
    05 Chevy Blazer
    Well if it's getting gas it's probably something electrical. Check your spark plugs, ignition coil...etc etc. I'm not much help in this area. Not a fan of carbs. Did it just not fire up for you today? Or did it just quit running while you were driving it?
    -Rafe-
    Things I have for sale.
    Random Festiva Parts
      Ck your dizzy and coil . Then timing belt . Good luck .
      New build on the way .
        If they're at all like EFIs there is an ignition power relay to check for (hidden near the headlight and inside the fender driver side), wire loop fuses in the block on the driver's side shock tower, ignition module and the ignition coil. Test light helps as does the Haynes manual.
        Do not overlook the possibility of a broken timing belt. I've done that. EFIs also have an idiot sensor within the dizzie that tells the computer that the dizzie is turning. Without that signal the car behaves as if it's dead in the water even though the dizzie physically is turning. Ya gotta love electronics.
          Just cut off at stop sign when I started to go.
          02 Honda Odyssey
          05 Chevy Blazer
            Thanks guy got it running again. It was the Coil wire.
            02 Honda Odyssey
            05 Chevy Blazer
              Easy fix! Good to hear!
              -Rafe-
